Free LioranBoard 2 Stream Deck/Animator [Deleted]
Status
Not open for further replies.
Hi!
I have a doubt, I want that when the same person uses the points of the channel twice in a row in less than 2 seconds for example for the effect to happen. Because it only happens once, and to happen the second you have to wait 10 seconds. NOTE: I don't have the Add to Request Queue active, shouldn't the effect be added immediately the second time the person asks?
Hello, many thanks for creating this great tool!
Where are my decks saved? I want to backup them.
Some other questions or feature requests:
- Is it possible to copy a deck? I would like to have two similar decks. I found copy/paste a button, but not copy/paste a whole deck.
- Is it possible to flip a source horizontally? So far I have not found a way to do this.
Thanks,
Micha
You can do this via a workaround. Open up the receiver folder (lioranboard/LioranBoard Receiver(PC) ), look for the config files. You can open these up with a text editor to see which config is which deck but it should be in order. Copy the config file of the one you want to make an extra of, and then make sure to number it with the next available number. i.e. you see config files going up to config4. In that case number your copied config config5.
Is there a way to control the deck from another PC? I'm trying to control my streaming PC from my Tablet PC and I don't know if that's possible. They're both on the same network. Thanks
Same as the mobile phone option for android, just select the proper IP and port of the PC that is running the receiver. On the PC that is running the receiver, use the batch file included to show your local IP and take the listen port from options. On the other PC run LioranBoard Stream deck(PC) and plug in the right numbers.
I was impressed by the generic concept you imagine to plugg with the OBS websocket.
I succeed to do all I need except two things:
feature #1 : I want to change the button name with a variable meaning the button label becomes dynamic.
feature #2 : what is the best way to make a timer included in your interface ?
Thanks a lot !
I need help
I've been trying to figure out how to make a simple button on my LioranBoard that mimics hockey within obs. I tried using both of these commands, "Trigger OBS Hotkey Name" and Trigger OBS Hotkey Sequence. Doing every variation, both together, both apart. But when I try to test the new button on the PC controller, its not triggering. I will also say the hotkeys I'm trying to trigger are added from the DYNAMIC DELAY PLUGIN. PLZ HELP! also I've gotten other buttons working just not with triggering hotkeys.
Did you find any answers to this because Im struggling with the same thing.
I need help
Ok, I found it out :)
If you use "Trigger OBS Hotkey Sequence" and say you have mapped the hotkey in OBS to F5, in the Trigger it needs to say OBS_KEY_F5
If the trigger is say ctrl+H it needs to say OBS_KEY_H and the crtl needs to be set to true.
Here is the list: https://github.com/obsproject/obs-studio/blob/master/libobs/obs-hotkeys.h
Use the names in brackets ()
Hi!
Does anyone here use the Lioranboard on a mobile phone / tablet?
I tried it yesterday, installed the APK, configured the IP port, and I can't connect to the computer, always saying that I lost the connection.
I put the IP below
Forget carecov, it is very rare for someone to help here, I have asked for help here twice and no answer ... anyway ...
Is there a tutorial for connecting Lioran bord stream deck on a laptop and connect to a receiver / OBS on another laptop?
Wonderful piece of a lot of work Lioran!
I found the solution here
Extra info! You have to start the LioranBoard receiver before you can find ' connect.ini '
Not sure where to post this, and apologies if this gets convoluted.
My setup is OBS Studio streaming to Youtube. I'm using OBS.Ninja to bring in 2-3 other people into an OBS scene (as browser sources) for a sports talk show. I've been looking at options for soundboards, and found Lioran really easy to set up and use. However, I'm having an issue with the audio. In each browser scene I choose "Control audio via OBS" so that I can put filters on the audio (compressor, limiter, gate). When I do this, I have to mute the desktop audio so that there's no echo on the stream. However, when I mute the desktop audio, the sounds from Lioranboard don't play.
Any ideas on how to set this up? My ideal setup would be to have Lioranboard show up as a separate audio channel in the mixer so I can control it separately, but it seems to be tied to the desktop audio. Thanks!
Hi, I am using a Go XLR with this board. I want to have alerts output in the sample channel-line. Right now, its sending the sound to the system default. Any way to change the output? Thanks
hi,I started using your board a week ago for point redeem effects and was wandering,is there any way to derive the sounds played by the board to a specific sound channel?
I use voicemeeter and like to maintain everything split into channels for editing purposes,but even though I set them to my alert channel,they seem to keep coming from the default one
I've had this problem here and there with certain applications as well. Some apps seem to not respect what device you tell it to play audio out of. Lioran board seems to be one of them but it might not even be a fault of lioran board itself and rather some windows or audio driver bug. Some games (I think usually unity but not ALL unity games) do this and I can't for the life of me figure out why.
I have an Asus Crosshair Hero 7 mobo and I use the digital channel as an extra channel. It works with most things, but yeah, every now and then some app will just refuse to respect that setting and just play out of the default device.
@lioran Source Change Settings doesn't seem to let you select the scene in which you're referencing a source. Is this intended?
I was wanting to adjust the cropping on my Chat browser source in a particular scene on the fly, but I can't select which one to modify!
Hey man! i absolutely love this app with the ability to be able to change stuff in mystream with the chat, i am curious is there anyway you could set this up to work on YouTube As well? and possibly Facebook?
Status
