Free LioranBoard 2 Stream Deck/Animator [Deleted]
Status
Not open for further replies.
Hello All
After OBS Studio update to version 26.1.1 (64 bit) wen starting LioranBoard it shows the window and close it really fast. On Windows event Id got generic error Event ID 1000 exception code 0xc0000005.
LioranBoard version was 1.3.8.0 update to 1.4.1.0 same error.
Need help, any ideas?
Tank you
Hello All
Tank you
Yes thats happening to me too. I added new files to reciever folder, I reinstalled the websocket, IM not sure waht else to do
Is there a way to get a sound effect to play based on a chat trigger when the word appears anywhere in the sentence? It works for the single worg, but I want it to catch it no matter where it shows up.
Hi @lioran , thanks for all the work you've put into this wonderful program. It's awesome while using it on Twitch, although I stream on Facebook Gaming too and I think me and tons of people would love to have some integration with FB, there are no channel points but maybe having Lioranboard buttons react to chat messages and specific cheering alerts would be awesome! Plus the community in Facebook Gaming is starting to grow a lot. Anyway, thanks for LioranBoard and I hope this keeps growing!
Hey guys! Maybe I'm stupid, but I don't understand why my LioranBoard doesn't want to work with Phasmophobia. I created a button for keyboard macro by twitch point. When I tested it in some document (ms word or something else) I see the letter what I added in keyboard macro. But I have nothing in Phasmophobia. Maybe someone can help me? Please! And guys, please, sorry for my English. I try to be better in it)
I discovered that changing sound device back to original on the sound icon near the clock on task bar solved the problem (new NVidia driver installed HDMI sound device) ope it helps
Weird bug, when selecting "filter change visibility" it only shows 10 filters even if there are more in the Scene.
It seems like I can't search in this forum. I want to copy paste my current lioranboard config to another PC. I did this now from PC1 to USB and then from usb to PC 2. But Lioran doens't show my tab.
Hello there,
is it possible to use LiorianBoard also to control other streaming or conferencing platforms like zoom or MS Teams for example through a chat message?
Thanks!
I have lioranboard 1.39 setup and working. Is there a recommended way to upgrade in place to the new version? Anything I need to watch out for?
Hi all. I need your help if possible.
I've created a command triggered by twitch chat. Is there a way to stop this command from activating if I am in specific scenes(like BRB, Intermission or starting soon)?
The features are endless and I am just starting. Thanks
lioran updated LioranBoard Stream Deck/Animator with a new update entry:
Websocket 4.9.0 is a bigger deal then you think.
OBSwebsocket 4.9.0 came out this week and it brings some new commands that will change how lioranboard can operate. You can now create Sources and scenes from lioranboard. This allows users to create fully animated overlays and easily give them out to people as a group of files and all the user has to do is click the "Install Extension" button in lioranboard and install the LBE file you have included.(see the extension folder for more detail if you wish to create overlay system for people)...
After latest update LioranBoard does not seems to listen to twitch, when something gets triggered I get a message "no type for pubsub" and the trigger does not work.
I tried to reconnect to twitch but no luck
Ok, my bad, I had forgot to update the TSL Transmitter file XD, now it works :)
Hi! May I request one small thing?:
- That we could change our OBS Websocket IP (not only port). And perhaps being able to connect to more than 1 OBS Websocket (different pc's for complex stream setups).
How can I change the audio output? I have an Elagota Wave mic and would like to set it to output to the "SFW" virtual cable but it only plays through desktop despite changing the app sound setting on Windows 10.
I need help
I've been trying to figure out how to make a simple button on my LioranBoard that mimics hockey within obs. I tried using both of these commands, "Trigger OBS Hotkey Name" and Trigger OBS Hotkey Sequence. Doing every variation, both together, both apart. But when I try to test the new button on the PC controller, its not triggering. I will also say the hotkeys I'm trying to trigger are added from the DYNAMIC DELAY PLUGIN. PLZ HELP! also I've gotten other buttons working just not with triggering hotkeys.
I recently installed the Clip+edit extension and now my websocket refuses to connect OBS. I have tried to reinstall the websocket and it still does not work and now i dont know what to do.
Status
