Free LioranBoard 2 Stream Deck/Animator [Deleted]
Status
Not open for further replies.
How can I do toggle Source Change Visibility on one button? In latest version was a list with True / False / Toggle, now I only can pick Visible or not.
Toggle was removed because people were miss using it and it was a nightmare to help people figure out their things, such has having toggle twice in the same button. If you used toggle twice in the same button, you shouldn't use toggle. toggle should only be used for things like mic on/off and such, which can easily be replicated with a if statement.
This screenshot is a perfect example of why toggle had to go.
Thanks for answer :) Now I want to find option of appearance of button - for example when scene is visible then button is green and when scene is invisible then button is red. Thanks :)
Hello, I have every time the error message in the receiver "Problem when fetching data...", although I have enabled TLS 1.0/1.1/1.2 in the Internet options.
It is also not due to the firewall and virus scanner.
I also get this error message when connecting to Twitch Chat.
Can anyone help me?...
I have an essential question:
Which trigger do I have to use for a button in the streamdeck that triggers a hotkey defined in OBS, e.g. "alt+numpad 1"?
Hello! I've read in the documentation that returning to a previous scene would simply be inputting global.Main.previous_scene into the scene switcher. However, I've been getting this error.
I currently have it set up as such! Would appreciate any help! Thank you!
lioran updated LioranBoard 2 Stream Deck/Animator with a new update entry:
Warning of unofficial versions
This is a simple warning that, some of Lioranboard's asset have been compromised by disgruntal moderators.
This includes
The Lioranboard official discord
The @Lioranboard Twitter account
The Lioranboard unofficial documentation website
Leak of Lioranboard 2 Receiver Source code
What does this mean?. This means unofficial copies of Lioranboard could POSSIBLY appear online in thos particular areas or anywhere on the web which are not authorised or veted by me, So there is no telling...
Status
