Hey Doda, I think it may be possible by searching through your Windows' registry. Let me check.Is there an uninstaller for this plugin? I have deleted the files, but still have the virtuel cams in Zoom, Skype and so on. How can I delete them? :)
Hi all,
Virtual cam is working fine. However, any chance in connect spotify music in to the virtual cam using OBS? I've tried sources audio in/output and nothing happen - also VB cable (not working). Any thoughts?
Hi all,
Fenrir submitted a new resource:
OBS Virtualcam - Virtual camera plugin for OBS Studio
Could anyone, PLEASE, tell me how to get rid of this program? I don't recall downloading this add-on, but it has prevented my camera from working with Google Meet for the last 3 or so months. I've spent hours and hours trying to fix this problem. I've even uninstalled OBS and deleted any registry entries I could find, but nothing works. This program is interfering with my ability to work. Please help me get rid of it.Fenrir submitted a new resource:
C:\Program Files\obs-studio\data\obs-plugins\win-dshowdid you find any solution ?Anyone knows how to add a VirtualCam to Oracle VM VirtualBox?
how did you do thati tried using the dummy device but only get a blue preview
Discord displays your camera flipped, but it actually is showing it correctly on the other side ( I never get used to it ).weird issue I wanted to report, in discord the stream is mirrored compared to the one in OBS. I don't know for sure where the issue comes from but I thought it would be helpful to report it, I think it was discord treating the camera like a selfie camera. My quick fix was to just reverse the image in the preview window then do the process again with any saved files I might pull out of OBS.
