I have the same question!I was finally able to make the virtual camera work. But now I have another noob question. Is there a way to get the virtual cam to only display the video capture device, and not what I'm broadcasting?
Download VB-Cable (donationware) . . . did the trick for me. Settings for OBS --> Audio . . . Under Advanced section, Monitoring Device -- set the monitoring to VB-Cable. Then make sure your audio sources in OBS are each set to monitor (or monitor and output) in the advanced audio properties popup box. Then select VB-Cable in Zoom as the audio source. Works like a charm. :-)Wonderful camera but there NO SOUND? Does this plugin support the audio output of OBS in the same way so that I can send the audio from my OBS and select it as a microphone in Zoom?? If not, any ideas? So close to a solution that will allow OBS to be BOTH the camera and mic for my Zoom. Thank you!!
Fenrir submitted a new resource:
OBS Virtualcam - Virtual camera plugin for OBS Studio
Did you ever get an answer to this or figure out how to get the OBS virtual camera to show up as a camera option to choose in Powerpoint? I have the exact same challenge as you do (recording for a course) but haven't figured out how to do this after spending a couple of hours.Hi, thanks for providing this plugin. I have so far used it with zoom, skype, teams, jitsi, ... and it works flawlessly. I am now trying to record a presentation in powerpoint 2019 and have my greenscreened obs virtual cam output mounted in the recorded powerpoint presentation. For whatever reason, the OBS virtual cam is not showing up as one of the cameras that I can show in powerpoint in the recording mode. Only the two physical devices I have show up (the integrated webcam of the laptop and the webcam intetrated into the external monitor). Only those appear in "Device Manager" under "Cameras".
Before you ask: Why won't you let OBS do the recording? - This is for recording a lecture with lots of equations. Sometimes I get a sign wrong or spot some other mistake on the slides only after everything has been recorded. Or the equation numbering is wrong. Then using this approach I can still use my recorded video and audio (which is fine) to just re-render the video. If I do the recording by superimposing the webcam on the powerpoint output capture in OBS, then I would have to re-record the entire slide again and edit the whole thing in OpenShot...
Thanks for any advice!
Here's how I do that:I was finally able to make the virtual camera work. But now I have another noob question. Is there a way to get the virtual cam to only display the video capture device, and not what I'm broadcasting?
Then you should be able to use this virtual cam in other software, regardless what's currently broadcasting.
- Create a Scene with only the capture device or camera you want to send to Virtual Cam.
- Right clic the Scene > Filters.
- Add a VirtualCam filter and choose a name (doesn't matter).
- Select one of the virtual cams and hit Start (you have to do this every time you restart OBS)
Hope this help you.
I did all that previously but I can never get the OBS Virtual Camera to show up in powerpoint (see screenshots...I'm running windows 10 on a Mac). It appears that when OBS is running, it gets an exclusive "lock" on the built in camera (Facetime HD in this case) OBS Virtual camera is not available in powerpoint nor is the Facetime camera anymore (see screenshots), just two other virtual cameras from other apps which do show up for some reason. OBS Virtual Camera is also not available to other apps (at least in windows...on the Mac OS OBS Virtual Camera is available, but unfortunately Powerpoint slideshow video capture is not enabled on the Mac, only audio).
View attachment 66316View attachment 66317
anyone know how to use virtualcam as input in snap camera?
because, obs-virtualcam output is not detected at all in the snap cam.
I have this same issue. There is nothing in Power Point settings to be done. Getting this to work would be ACE!
having similar issues of installing but it not showing up at all.
Did any of you figure this out? I'm having the same issue. VirtalCam shows up and functions within OBS, but the virtual cameras do not actually appear in any other programs or in Device Manager.Bro, did you finded the fix ? I have the same issue.
