Roblox recording in a weird way
You might wanna show me more details such as what capture you're using (Display, Window, Game), its properties, your Recording settings, etc. so that I could help.
display and window both show same result and only on roblox, if i alt tabbed into something it would record that app just fine
And when i try game capture it says this:
Properties:
Recording:
srry for not sending in original didnt know it was needed
Yeah, in the log file is clear you're using window capture method.
You need to disable Windows DVR and enable Windows Game Mode.
Change the Recording Quality to High Quality, medium file size.
Make sure you're recording into a SSD M.2 (not SATA)
Is with this the recording goes well, try a better recording quality and see how it works.
sorry for coming back this late , i tried disabling windows DVR ,enabling game mode and high quality medium file size, but it still gives the same results any other fix maybe?
Please provide the test log file.
If you're watching the recorded video with windows player, of course it will look not so good. Use a better player, like VLC.
Also make sure there's no other app interfering with the normal functionality of the game and OBS.
