OBS No longer capturing display after system update
slackk
Complete log:
debug: Found portal inhibitor
debug: Attempted path: /usr/bin/..//usr/share/obs/obs-studio/locale/en-US.ini
debug: Attempted path: /usr/share/obs/obs-studio/locale/en-US.ini
debug: Attempted path: /usr/bin/..//usr/share/obs/obs-studio/locale.ini
debug: Attempted path: /usr/share/obs/obs-studio/locale.ini
debug: Attempted path: /usr/bin/..//usr/share/obs/obs-studio/locale/en-GB.ini
debug: Attempted path: /usr/share/obs/obs-studio/locale/en-GB.ini
info: Using preferred locale 'en-GB'
debug: Attempted path: /usr/bin/..//usr/share/obs/obs-studio/themes
debug: Attempted path: /usr/share/obs/obs-studio/themes
debug: Attempted path: /usr/bin/..//usr/share/obs/obs-studio/themes/
debug: Attempted path: /usr/share/obs/obs-studio/themes/
warning: Get on org.freedesktop.portal.Settings returned an invalid reply
info: Using EGL/X11
info: CPU Name: AMD Ryzen 5 5600G with Radeon Graphics
info: CPU Speed: 4305.724MHz
info: Physical Cores: 6, Logical Cores: 12
info: Physical Memory: 15841MB Total, 12901MB Free
info: Kernel Version: Linux 6.6.41_1
info: Distribution: "Void" Unknown
info: Desktop Environment: XFCE
info: Session Type: x11
info: Window System: X11.0, Vendor: The X.Org Foundation, Version: 1.21.1
info: Qt Version: 6.7.2 (runtime), 6.7.2 (compiled)
info: Portable mode: false
info: OBS 30.2.1 (linux)
info: ---------------------------------
info: audio settings reset:
    samples per sec: 48000
    speakers:        2
    max buffering:   960 milliseconds
    buffering type:  dynamically increasing
info: Initializing OpenGL...
info: Loading up OpenGL on adapter AMD AMD Radeon RX 6500 XT (radeonsi, navi24, LLVM 18.1.8, DRM 3.54, 6.6.41_1)
info: OpenGL loaded successfully, version 4.6 (Core Profile) Mesa 24.1.3, shading language 4.60
info: video settings reset:
    base resolution:   1920x1080
    output resolution: 1440x810
    downscale filter:  Bicubic
    fps:               60/1
    format:            NV12
    YUV mode:          Rec. 709/Partial
info: NV12 texture support enabled
info: P010 texture support not available
info: Audio monitoring device:
warning: Failed to load 'en-US' text for module: 'decklink-captions.so'
warning: Failed to load 'en-US' text for module: 'decklink-output-ui.so'
warning: Failed to load 'en-US' text for module: 'decklink.so'
libDeckLinkAPI.so: cannot open shared object file: No such file or directory
warning: A DeckLink iterator could not be created.  The DeckLink drivers may not be installed
warning: Failed to initialize module 'decklink.so'
warning: Failed to load 'en-US' text for module: 'frontend-tools.so'
warning: Failed to load 'en-US' text for module: 'image-source.so'
warning: Failed to load 'en-US' text for module: 'linux-alsa.so'
warning: Failed to load 'en-US' text for module: 'linux-capture.so'
warning: Failed to load 'en-US' text for module: 'linux-jack.so'
warning: Failed to load 'en-US' text for module: 'linux-pipewire.so'
info: [pipewire] No capture sources available
warning: Failed to load 'en-US' text for module: 'linux-pulseaudio.so'
warning: Failed to load 'en-US' text for module: 'linux-v4l2.so'
warning: Failed to load 'en-US' text for module: 'obs-ffmpeg.so'
error: os_dlopen(libnvidia-encode.so.1->libnvidia-encode.so.1): libnvidia-encode.so.1: cannot open shared object file: No such file or directory
error: VAAPI: Failed to initialize display in vaapi_device_h264_supported
info: FFmpeg VAAPI H264 encoding not supported
info: FFmpeg VAAPI AV1 encoding not supported
error: VAAPI: Failed to initialize display in vaapi_device_hevc_supported
info: FFmpeg VAAPI HEVC encoding not supported
warning: Failed to load 'en-US' text for module: 'obs-filters.so'
warning: Failed to load 'en-US' text for module: 'obs-outputs.so'
warning: Failed to load 'en-US' text for module: 'obs-transitions.so'
warning: Failed to load 'en-US' text for module: 'obs-webrtc.so'
warning: Failed to load 'en-US' text for module: 'obs-x264.so'
warning: Failed to load 'en-US' text for module: 'rtmp-services.so'
warning: Failed to load 'en-US' text for module: 'text-freetype2.so'
warning: Failed to load 'en-US' text for module: 'vlc-video.so'
info: [vlc-video]: VLC 3.0.21 Vetinari found, VLC video source enabled
info:   Loaded Modules:
info:     vlc-video.so
info:     text-freetype2.so
info:     rtmp-services.so
info:     obs-x264.so
info:     obs-webrtc.so
info:     obs-transitions.so
info:     obs-outputs.so
info:     obs-filters.so
info:     obs-ffmpeg.so
info:     linux-v4l2.so
info:     linux-pulseaudio.so
info:     linux-pipewire.so
info:     linux-jack.so
info:     linux-capture.so
info:     linux-alsa.so
info:     image-source.so
info:     frontend-tools.so
info:     decklink-output-ui.so
info:     decklink-captions.so
info: Available Encoders:
info:   Video Encoders:
info:     - ffmpeg_svt_av1 (SVT-AV1)
info:     - ffmpeg_aom_av1 (AOM AV1)
info:     - obs_x264 (x264)
info:   Audio Encoders:
info:     - ffmpeg_aac (FFmpegAAC)
info:     - ffmpeg_opus (FFmpegOpus)
info:     - ffmpeg_pcm_s16le (FFmpegPCM16Bit)
info:     - ffmpeg_pcm_s24le (FFmpegPCM24Bit)
info:     - ffmpeg_pcm_f32le (FFmpegPCM32BitFloat)
info:     - ffmpeg_alac (FFmpegALAC)
info:     - ffmpeg_flac (FFmpegFLAC)
info: ==== Startup complete ===============================================
info: All scene data cleared
info: ------------------------------------------------
error: Could not find fade_transition.effect
error: Failed to create source 'FadeTransition'!
info: pulse-input: Server name: 'pulseaudio 16.1'
info: pulse-input: Audio format: s16le, 44100 Hz, 2 channels
info: pulse-input: Started recording from 'alsa_output.pci-0000_09_00.6.analog-stereo.monitor' (default)
info: [Loaded global audio device]: 'Desktop Audio'
info: pulse-input: Started recording from 'alsa_input.pci-0000_09_00.6.analog-stereo' (default)
info: [Loaded global audio device]: 'Mic/Aux'
info: v4l2-input: Start capture from /dev/video0
error: v4l2-input: Unable to open device
error: v4l2-input: Initialization failed, errno: No such file or directory
error: Failed to create source 'Crop/Pad'!
info: xshm-input: Geometry 1920x1080 @ 0,0
info: Switched to scene 'Scene'
info: Loaded scenes:
info: - scene 'Scene':
info:     - source: 'Mic' (pulse_input_capture)
info:         - filter: '3-Band Equaliser' (basic_eq_filter)
info:     - source: 'Video Capture Device (V4L2)' (v4l2_input)
info:         - filter: 'Crop/Pad' (crop_filter)
info:     - source: 'X11SharedMemoryDisplayInput 2' (xshm_input)
info: - scene 'Scene 2':
info:     - source: 'X11SharedMemoryDisplayInput' (xshm_input)
warning: QDBusTrayIcon encountered a D-Bus error: QDBusError("org.freedesktop.DBus.Error.UnknownObject", "No such object path '/StatusNotifierWatcher'")
info: adding 42 milliseconds of audio buffering, total audio buffering is now 42 milliseconds (source: Mic/Aux)
I am having the same issue:
❯ obs
info: Using EGL/X11
info: CPU Name: AMD Ryzen 9 3900X 12-Core Processor
info: CPU Speed: 2200.000MHz
info: Physical Cores: 12, Logical Cores: 24
info: Physical Memory: 128734MB Total, 120694MB Free
info: Kernel Version: Linux 6.6.43_1
info: Desktop Environment: XFCE (xfce)
speakers: 2
info: Loading up OpenGL on adapter NVIDIA Corporation NVIDIA GeForce RTX 2070 SUPER/PCIe/SSE2
info: OpenGL loaded successfully, version 3.3.0 NVIDIA 550.100, shading language 3.30 NVIDIA via Cg compiler
output resolution: 1280x720
fps: 30/1
format: NV12
info: NVENC supported
info: vlc-video.so
info: obs-x264.so
info: obs-webrtc.so
info: obs-ffmpeg.so
info: linux-v4l2.so
info: linux-jack.so
info: linux-alsa.so
info: - ffmpeg_nvenc (NVIDIA NVENC H.264 (FFmpeg))
info: - ffmpeg_hevc_nvenc (NVIDIA NVENC HEVC (FFmpeg))
info: pulse-input: Started recording from 'alsa_output.usb-Burr-Brown_from_TI_USB_Audio_CODEC-00.analog-stereo-output.monitor' (default)
info: pulse-input: Started recording from 'alsa_input.usb-Burr-Brown_from_TI_USB_Audio_CODEC-00.analog-stereo-input' (default)
info: [window-capture: 'XCCapture'] update settings:
title: Desktop
class: xfdesktop
info: - source: 'XCCapture' (xcomposite_input)
Packages installed: see attached.
I HAVE FOUND THE SOLUTION (that's at least working for me, lol)! You just have to change the transition effect to CutTransition. I've noticed this after switching to studio mode and saw the screen flashing for a frame when I spammed the CutTransition from under quick transitions. We're all also using Void btw so there may be something to do with their package.
