Bug Report OBS crashing
Do you get the same crashes on OBS Studio? Classic has been out of development for over a year now. It's strongly recommended that you update to OBS Studio. If you have a complicated scene setup, you can use the converter found here to convert your scenes to Studio.
I tried OBS Studio but when I doucle-click on it, it doesn't start but it is in the tasks manager.
This is likely a known issue with the Browser Source plugin. Try just launching it again, and it should start normally. This bug should be fixed in the next OBS Studio release, which is due very soon.
