Question / Help I'm having problems with my stream
VWave
So i wanted to get into streaming since i got a new PC, but the stream gameplay is either choppy (but is perfectly normal how i see it), stream ends on its own or quality is too shit.
PC Specs:
CPU: Intel Core i5 - 3470 3.20 GHz 3.60 GHz
GPU: Radeon RX 550 Series 4 GB GDDR 4
RAM: 8GB Vengeance RAM
oh and i stream on twitch btw
In the log that actually has the streaming attempt, you're overloading your video card MASSIVELY when using the AMD encoder.
There was no attempt to use x264 in that log.
Also, update to 22.0.1
When i download 22.0.1 from the website, will it save my stuff?
When you download and install without uninstalling your settings and scenes will remain intact.
That log doesn't show a streaming attempt, and you need to manually update your OBS to current.
I need a log from current with a streaming session
