Resource icon
Encoder Region of Interest Editor 1.1.1
I don’t think that Kaspersky is a bad antivirus, as evidenced by numerous tests and awards. Okay, can I consider this a false positive?
I'm a content creator and I can't just tell people your antivirus is crap.
It's a false positive, yeah. The installer framework is what gets falsely flagged because some malicious software uses it. The zip/dll itself should show no detections.
I have a small problem with the bitrate when streaming to Twitch.
Tried a lot of different settings, but the bitrate goes up to 9k - 11k bitrate, when I stream with 8k with the x.264 codec.
When I stream with HEVC (I'am in a Twitch Enhanced Broadcast Beta User) that's not a problem and works like a charm.
Only with x.264 the bitrate got heavy spikes, is there a fix or workaround for that?
Hello!
I just installed your ROI Plugin.
When I open the Editor I'm not getting any visual for Center Focus or Manual Focus. Only the Scene Item one works but even that doesn't let me select things within a Group as I do that for organizational.
I'm mainly hoping someone can help with getting Center Focus and Manual Focus working.
Is this plugin abandoned?
Tried to use this, but the user interface is anything but appealing, and no chance since July 2024.
Missing
- Drag and drop
- Even Sliders for the values
- Individual Names for the regions
- Profiles for different games
The technology itself is ingenious. But the way the UI is designed, you really have to force yourself to use it. It's a pain to create more than 2 regions in a scene.
If I make a Manual Region and make it 1920x1080 and prioritize it... will my whole scene just be clearer? Or what will this do to my streams output?
Is this version compatible with version 31.0.1?
I installed it there and can't see any difference. Or could it be because I have my camera in a group with the facecam frame in the scene?
This is one of my all-time favorite OBS plugins. Unfortunately, it's broken on OBS 31. It will only prioritize the bottom half of the sources I point it to.
Great plug in you did what billion dollar companies failed to do.
Great for streaming but, on re-encoding the pixelated zone, i guess it may give work to the encoder and lower the general quality because of that.
So.
How can i apply the same zones to ffmpeg or any encoder?
Maybe offer your project to AMD to boost their radeon boost technology and earn some accolades, you are good.
PD: Is there any chance to lower the refresh rate of the low priority zone so there is even less variance and less work for the encoder??
well maybe i have to boost the pixelation size to get the same effect, but still, just an idea.
Hi guys,
Is there a way to make the plugin work with OBS 29.1.3 version? I don't want to upgrade my OBS.
Thanks!
Hi guys,
Thanks!
Why are you sticking with such an old version of OBS Studio, curious? Have you tried any of the newer releases? Most plugins nowadays will want much more recent releases of OBS Studio before they'll even load.
--Katt. =^.^=
Is it possible that it doesn't work with OBS version 32.1.1? I updated and now I have the feeling that it's no longer working.
Yeah, I don't think this is working. Trying to preview it now just crashes OBS and I see no noticeable effect when streaming.
Hey Everyone,
I was also affected so I've made a patch for this and sent the PR to the original maintainer but in short, there was a change to the FFmpeg version bundled with OBS, requiring a change to the original version.
If you want just the fixed version, I've placed it here (you can either copy over the dll on it's own or copy the whole folder) but I've also gone ahead and fixed some of the other minor issues: ROI-Editor v1.2.0 (fixes OBS 32.2.X crash)
Also including a scan of the zip from virustotal given I'm a new poster here, but feel free to do the same yourself to verify (you always should!): https://www.virustotal.com/gui/url/4ad89714ea25df0d612c84724d5dd4b28e09289e4025e783c4844173e47acf21
And because I had some more time, I did a seperate release and added some features in my own forked version - feel free to send me some feature requests if you have any and I'll try and get them merged back to the original if the dev is still around:
ROI-Editor v1.3.0 - please note this one is brand new, test it before you try and go live! I have, but you should too!
New features:
- OBS 32.2.1 compatibility (deps refresh, current plugintemplate cmake, Qt 6.11 fixes)
- Direct manipulation in the preview: drag to create, move and resize regions
- Scene item regions that track live mid-stream, group-aware, plus manual regions pinnable to an item
- Center focus with separate X/Y radii
- An image-mask region type (greyscale image drives the ROI, hot-reloaded when the file changes)
- Per-region hotkeys and an obs-websocket vendor API
- A stepped heatmap with a block histogram, and output scaling support (the old "scaling not
supported" limitation is gone)
