DroidCam OBS Camera
DroidCam OBS Camera 2.5.0
Hello, i install the 2.5.0 setup .exe, but the new options are not present in obs, and i see dat :
Strange... is it normal ?
Latest 2.5.0 Plugin Breaks / Shows black screen when using AVC or HEVC coded with activated hw acceleration. Only MJPeg + 1080p works.
4k30fps was working with 2.4.2 on AVC but now its unusable.
Main setup is iphone15pro with a usb-c 20gbps cable.
The phone actually seems to be "fine" it shows that its connected and the usual "stats" but within obs, its all black as seen on the screenshot.
Also tried via WiFi (5ghz) , different iphone, different cable, all same results.
It shows a picture when HW Accel. is disabled, but the latency / lag from it makes it borderline unusuable.
Not sure if there is anything i can do on my side, but for now i stay with Plugin Version 2.4.2.
One of the changes in 2.5.0 was the addition of D3D12 as the main hw decoding option for Windows , and my initial hunch is this is the likely problem. I will make a note switch the order and stick with D3D11 as the default. If you could upload an OBS log with the video coming out blank, that would be really helpful (in OBS, use Help -> Upload log or find the previous logs. you can also email this to support@dev47apps.com).
@dev47 Thank you for the great app and OBS plugin!
I found out that version 2.5.0 of the plugin still doesn't work with libavcodec-62. Ubuntu 26.04 (Resolute Raccoon) has been released almost month ago and has had libavcodec-62 and OBS 32.1.0. Ubuntu don't like flatpak, so I use repo version of OBS but still cannot use Droidcam plugin.
I see the note for version 2.4.3 stated "downloads will be available after the OBS Studio PPA/Flatpak officially switch to FFMpeg 8." OBS Studio PPA version 32.1.2 uses `Depends: ... libavcodec62 (>= 7:8.0.1), ...`.
I just want to ask when do you plan to publish the released files at least for 2.4.3 plugin version?
now that you mention it, it actually shows an hw decode error in the log
19:09:43.522: error: hardware accelerator failed to decode picture
I attached 2 Log Files - since i tried it with 2 different obs versions (the latest official release and the closed beta twitch enhanced version)
Thank you in advance for your hard work! One of the handfull plugins i wasnt dissapointed in spending money for the full version
Hi team Droidcam and droidcam users!
I bought Droidcam to get the most out of my camera. Let me tell you what my current challenges are:
So my setup is:
Livestreaming DJ sets on TikTok LIVE. I use OBS Studio with the Virtual Camera send to TikTok Studio. This all works perfectly after adding Droicam in OBS as Source.
Now the challenges:
I want to have the best picture quality so I figured out that I need to use Camera 0 on 1.0x zoom. This way my Samsung S25 Ultra uses the main camera (so the biggest sensor). Also with this 1.0x zoom you can manually set the focus which is great.
The challenges I have are with AWB and EV level.
So first the EV level:
I can crank up the light output of my Elgato Key Light and this way I can lower the EV value to as much as - 20 if I want to. The other way is to put the EV value on 0/default and turn down my Elgato Key Light. Or of course everything in between this. Which is the best way to go for this?
Then there is the AWB. I found out in this topic that for the Droidcam dev team it was not possible to have a "real" color scale (in Kelvin) for the silder but that it should be between 2000K (silder 0) and 10000K (slider 100). Is that still applicable for the current version combined with my S25 Ultra?
And here is what is strange to me as for the AWB: when I put my Elgato Key Light on 5600k and the silder in Droidcam in the middle it should theoretically be around 5600k but it seems way too flat/blue. When putting it on AUTO in droidcam it seems to become to red. And what is also strange to me is that I cannot achieve the same result with the manual slider that auto gives me. So what I mean is that putting the AWB setting on AUTO and compare this with the manual silder there is not a single value (0-100) that comes even close to the AUTO outcome.
Any input?
Hey @ZYNCTECHNO -
#1) This is mostly up to you, but I would say keep EV close to zero and adjust your lighting instead. EV=0 means less image processing.
#2) Android has finally introduced the option to set WB with kelvins. The code changes for this are ready and are pending release (soon™). For the time being, you will just need to eyeball the 0-100 slider to your visual taste, or just let auto do its thing and lock it.
Thanks and makes sense. But things got more interesting yesterday as I did some more testing. In addition to my previous message I made a lot of screenshots. Maybe it seems a bit complicated, but is is actually pretty simple once you understand what I did. Reason I did this so you can establish if there is something wrong with the white balance setting in Droidcam 9.2 on my Android S25 Ultra. I have 2 Elgato Key Lights which can be set to a specific degree (Kelvin). So my ultimate goals is to have skin tones from my face as natural as possible (5600K I assume?)
So I THINK (but I m not sure!!!) that the White Balance silder in Droidcam is broken. I say this because White Balance on AUTO in Droidcam gives an picture outcome that CANNOT be realized with the manual slider. Hope you understand what I mean but when you check the screenshots it will make sense to you.
LINK TO SCREENSHOTS > https://limewire.com/d/i8NUm#Ettpn1fFw1
I did screenshots with:
AWB Droidcam + Elgato Light on 2900K
AWB Droidcam + Elgato Light on 5600K
AWB Droidcam + Elgato Light on 7000K
WB0 Droidcam + Elgato Light on 2900K
WB0 Droidcam + Elgato Light on 5600K
WB0 Droidcam + Elgato Light on 7000K
WB30 Droidcam + Elgato Light on 2900K
WB30 Droidcam + Elgato Light on 5600K
WB30 Droidcam + Elgato Light on 7000K
WB50 Droidcam + Elgato Light on 2900K
WB50 Droidcam + Elgato Light on 5600K
WB50 Droidcam + Elgato Light on 7000K
WB60 Droidcam + Elgato Light on 2900K
WB60 Droidcam + Elgato Light on 5600K
WB60 Droidcam + Elgato Light on 7000K
WB80 Droidcam + Elgato Light on 2900K
WB80 Droidcam + Elgato Light on 5600K
WB80 Droidcam + Elgato Light on 7000K
WB100 Droidcam + Elgato Light on 2900K
WB100 Droidcam + Elgato Light on 5600K
WB100 Droidcam + Elgato Light on 7000K
Hey Devs,
I updated OBS to the latest RC version and the latest Droidcam cannot be found in the new sources section anywhere. All the iOS devices show up but no Droidcam. I had to rollback OBS Studio to 32.1.0 so that it could be found under sources. It would hoverever show under the Plugin Manager though but that’s it.
Not sure is ifs OBS Studio or the plugin but if someone who knows what they are doing could take a look, that would be great.
PS I’m using MacOS on latest version of it.
Hi @sheeptease , OBS 32.2 has updated FFMpeg which means you will need to update DroidCam. Click on Downloads here and get the droidcam obs 2.5.1 pre-release which is on Github.
Hello ! My phone have 60 img/s recording ont the défault app. Why impossible to have 60 img/s on droid cam app ? Any idea ? My phoe is Redmi note 14... Thanks ! I'v try everything in options... maybe something hide ?
@dev47, hope this message finds you well.
Please investigate and fix multi-device support in version 2.5.x. For context, I use a two-iPhone setup for my streaming purposes. With version 2.4.2 the plugin picks up both of my iPhones via USB with no issues whatsoever, and I can use both "cameras" simultaneously with no problems. When I updated to version 2.5.1, the plugin seemed to have difficulty detecting both iPhones, and I could only ever get one or the other to work consistently. As such, I downgraded back to version 2.4.2 because it works really well in that regard. If you require me to provide you with any logs or system specs or anything else, please let me know.
Also, I love this plugin. I bought the pro license years ago, and have gotten a ton of value out of it. I could not find any support portals on your website. Do you have a ko-fi account or a patreon or anything similar?
Cheers,
Alex
Please see "Android Device Support" at https://droidcam.app/obs/usage/#faq
There is a chance your phone limits 60fps to its own camera app only. The camera probe linked there will show the detected options.
