I recently tweeted about an issue surrounding crash I was having with OBS-Studio 0.11.1 (and had happened previously on 0.10.x).
The setup is as follows:
- An Avermedia capture card pulling video from a BMD Atem Studio.
-The computer used for streaming is the same used to control the ATEM & has the ATEM software installed.
In OBS-Studio I have a scene with a single source, a Video Capture Device for the Avermedia card.
The issue results under the following condition: If I attempt to open the Properties for the Video Capture Source (64bit & 32bit), or also attempt to add a Video Capture Source (32bit & 64bit) I get the crash message. If the fault occurs whilst streaming, it is generally accompanied by stuttering in the audio and sometimes after a scene switch (there is a scene with a static image & an mp3 playing).
An yep... have tried turning it off and on again. :p
