Cursor Capture
Suslik V
Edit: Size not a problem any more - https://github.com/obsproject/obs-studio/commit/a75724d8a557b0081ca0d6f03e8c8d02c4aade04
The Hand (H) tool from SmoothDraw v3.2.11.0 now has normal size in capture window.
_______________________
I made new application in Qt 5.8.0, list:
#include "mainwindow.h"
#include "ui_mainwindow.h"
MainWindow::MainWindow(QWidget *parent) :
    QMainWindow(parent),
    ui(new Ui::MainWindow)
    ui->setupUi(this);
    QCursor cursor01 = QCursor(QPixmap("cursor01.png"), 0, 0);
    this->setCursor(cursor01);
MainWindow::~MainWindow()
    delete ui;
When I use Window Capture (win10), the cursor rendered in OBS Studio (v21.1.0) downscaled (square picture) - is this normal? Previously, I tested it in win7 and there both Window Capture and Display Capture renders it as square instead of rectangle.
